Clip Colors
Ludmil Kazakov
Clip Colors
on Mar 1, 2018 at 6:17:59 am
How can the sequence update the clip colors? basically when i first import footage by default its one color.. then i start changing colors of the clips but they only appear so in the folder and not on the timeline. is there a way to refresh the sequence/timeline to reflect the changed clip colors?
like in avid, when you change a clip's color it changes on the timeline right away.. there is also a refresh sequence option.. but not in premiere..
Tero Ahlfors
Re: Clip Colors
on Mar 1, 2018 at 7:48:18 am
Go into your project settings - general and tick the "display the project item name and label color for all instances"-box.
Ludmil Kazakov
Re: Clip Colors
on Mar 1, 2018 at 7:51:17 am
YES!! thank you!!!
