Transferring project from Premiere Pro to Avid Media Composer
philip knowlton
on Feb 24, 2018 at 5:14:04 pm
I'm handing off an feature doc edit that I cut in Premiere Pro to a finishing editor who works in Avid. What is the best way to transfer the project over? (Sorry if this has been addressed already, most of the threads I found were a few years old, hoping there might be an update).
philip
Shane Ross
Re: Transferring project from Premiere Pro to Avid Media Composer
on Feb 24, 2018 at 9:13:54 pm
You can't transfer full projects, only sequences. So if they plan on taking over editing and want to do it in Avid, then someone will have to reimport and re-organize all of the media...and you can send the cut as it exists over.
But none of the media in the cut will relink to the newly organized project...because you'll have to export an AAF, send that to Resolve, then render that media out as Avid media and export an AAF to Avid. And it'll relink to THAT media, but that media will be different....because you converted it...and it's not linked to the media they import.
It is not a good idea to try to change the editing software mid way. They either need to learn how to cut with Premiere, or get ready to spend a lot of time building the project up from scratch.
Shane
Little Frog Post
Eric Merklein
on Feb 25, 2018 at 2:45:36 pm
Shane is correct. Too bad though. Just like Windows and Apple.
philip knowlton
on Mar 3, 2018 at 6:04:25 pm
Thanks so much Shane! Unfortunately that's what I suspected, but I was wishing there might be some new workaround.
Thanks again!
philip
sam steele
on May 23, 2018 at 12:48:03 pm
Hey Philip,
Don't suppose you had any luck on this??
