Changing frame rate in premiere pro
Treva Allred
on Feb 22, 2018 at 1:55:34 am
Hello! I am fairly new with premiere pro and I was wondering if there was a way to change a low frame rate like 24
To a higher frame rate of 60
I recorded a video and didn’t realize I was recording in 24fps I’m want to do some slow motion edits in my video
But doing slow motion with a 24fps clip doesn’t look so good. Could someone give me some suggestions on what I can do?bz
Mateo Brooks
Re: Changing frame rate in premiere pro
on Feb 22, 2018 at 1:17:09 pm
Unfortunately if you filmed it in 24fps there's not really a way to make it look much better. You could try changing the Time Interpolation setting in the Clip Speed/Duration video to Optical Flow. There's usually a bit of weird distortion but I think it's the best you can do with a 24fps clip.
In the future if you can, you'll have record in 60fps if you want a clean looking slow motion.
Dave LaRonde
on Feb 22, 2018 at 3:14:35 pm
Yeah -- reshoot the video so you have something to work with. Otherwise, you're just polishing a turd.
Dave LaRonde
Promotion Producer
Shane Ross
on Feb 22, 2018 at 3:21:29 pm
There is a plugin for After Effects for making 24fps and 30fps into decent slow motion called Twixtor that you can try.
Shane
Little Frog Post
