Premiere Pro CC 2018 - problems importing 1080HD AVI files
Bruce Rutland
on Feb 21, 2018 at 10:45:47 am
I'm trying to import 1080HD AVI files into Premiere Pro CC 2018 (PC Windows) and I keep getting a "File Import Failure" message "Unsupported format or damaged file" and can't continue. I've been using PP CS5 up to now and just switched to the new version yesterday. I've never had a problem before. I know it's not a corrupt file as have tried dozens of files and they were all fine in the previous version.
Any ideas? Thanks in advance. Bruce
Tero Ahlfors
Re: Premiere Pro CC 2018 - problems importing 1080HD AVI files
on Feb 21, 2018 at 11:00:10 am
Where did this file come from and what codec is in it?
Bruce Rutland
on Feb 21, 2018 at 11:39:10 am
Thanks for the reply.
This is all the information I could find on the file formats...
Video
Frame width 1920
Frame height 1080
Data rate 63139kbps
Total bitrate 64675kbps
Frame rate 25 frames/second
Audio
Bit rate 1536bps
Channels 2 (stereo)
Audio sample rate 48 kHz
Bruce Rutland
on Feb 21, 2018 at 11:43:07 am
It was originally captured in Premiere Pro CS5 from a Blackmagic Teranex 2D using a Decklink SDI 4K (Blackmagic) card.
Jeff Pulera
on Feb 21, 2018 at 8:24:51 pm
You need the Black Magic M-JPEG .avi codec to play those files, available by installing Black Magic capture card drivers.
Go to this page: https://www.blackmagicdesign.com/support/family/capture-and-playback
Look under Latest Downloads - Desktop Video 10.9.11 for Windows
Click WINDOWS then skip entering any info and select DOWNLOAD ONLY at lower left. Download and install driver, then you should be able to play/edit those files. CLOSE Premiere when installing.
Jeff
Jeff Pulera
Safe Harbor Computers
Bruce Rutland
on Feb 27, 2018 at 8:25:11 pm
Thanks Jeff - I followed your instructions and all working now!
You're a star... All the best, Bruce
