Bug or Feature? Sometimes can't resize clips in Program Monitor
Jonny Price
on Feb 20, 2018 at 7:13:37 pm
This issue has been affecting me for MONTHS. Sometimes, seemingly randomly, I won't be able to resize or move a clip in the Project monitor, the box / guides to do so will disappear. This only way to fix this is to do something else that doesn't require resizing and hope it returns to normal later, or to restart the program, both of which aren't ideal and have cost me tons of time due to this happening so often.
I was able to recreate this in a few minutes using some random footage I found on my Desktop:
It's also important to note that I never had this issue with Premiere 2017 EVER, it was only when I switched to 2018 that this is affecting me. I can still use 2017 but I want to be able to utilize the new VFR support as well as a few other features, and I see others using 2018 without any problems, so whats going on with mine?
I've reinstalled the program multiple times, reinstalled Windows entirely formatting my drive multiple times, changed pretty much every setting I can think of in the software and windows, and the issue still persists.
I'm wondering if this is a feature I'm unaware of and not using correctly, such as one which will lock the movement of the object and I'm somehow accidentally activating it?
Sometimes random settings can affect Premiere, such as previously I was having performance issues and for some reason disabling "Fade or slide ToolTips into view" in Windows performance options fixed that for me, I was wondering if there would be a similar fix for this.
This makes it literally impossible for me to edit properly in Premiere Pro 2018, so any help is appreciated, thanks.
