Play In - Out
Abe Froman
Play In - Out
on Feb 17, 2018 at 3:03:44 am
Our shop is transitioning from Avid to Premiere Pro, and there is a function for which I'm trying to find the equivalent. On Avid, you can mark IN and OUT on your sequence, and a mark on your b-roll (either an IN or OUT). Then you can play IN to OUT to preview what part of the clip will be used in the timeline. Can you do anything like that on Premiere?
Dave LaRonde
Re: Play In - Out
on Feb 17, 2018 at 4:53:09 pm
I haven't found one yet, and I run both. It'll be cool to learn if one exists.
Not that I do any complicated cutting in Avid....
Dave LaRonde
Promotion Producer
Jorn Bergmans
Re: Play In - Out
on Feb 19, 2018 at 2:22:29 pm
There is an option in Premiere called 'Play In to Out'. There's also an option to play around in-out with a two second preroll/postroll.
The default shortcut for Premiere keybindings is ALT+K and play around is SHIFT+SPACE
The default shortcut for FCP7 keys is SHIFT+\ and play around is SHIFT+SPACE
These will always play the currently active window, no matter if that is source, program, ref or timeline. Anything that can contain in- and outpoints will have a play in to out option.
