Burning Captions Into Video - Problems
Juan David Romero
on Feb 15, 2018 at 12:50:04 pm
I am having a huge problem. I created a file of captions for my film, which is 25 minutes.
Then I decided to move the captions around, so I made a cut in the 'captions' in the sequence and simply moved that to where I wanted it.
As soon as I did that the captions disappeared. I can see them in the sequence and the video too, but when I try to edit them I can't see them on the 'captions' tab.
I also tried to export the captions as 'open captions' to make sure they burnt into the video because I need it to be seen in the .mov file, but they don't show up. Help!
Phillip Brock
Re: Burning Captions Into Video - Problems
on Feb 16, 2018 at 4:10:40 pm
This doesn't really answer your question but I would load your video into Rev.com and let them caption it and send you files so you can test it out on your timeline. You can also go back to auto saved project files when it was working.
Andreas Kiel
on Feb 19, 2018 at 8:41:34 pm
You can try to export SRT and use my premiereTitles to convert them to Graphic Text.
http://www.spherico.com/filmtools/TitleExchange/PTI/
direct download:
http://www.spherico.com/filmtools/TitleExchange/PTI/pti.dmg
It's free till April!
Spherico
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
