Key a different color into a photoshop title
Anthony Vamvakitis
on Feb 13, 2018 at 7:18:29 pm
I use to do this trick in FCP7 and can't quite figure it out here.
1. Graphic artist sent us Lower 3rds with Alpha.
2. When edited into sequence, some backgrounds make the 2nd line of lower 3rd difficult to read.
3. I would like to create a colored rectangle with a more saturated color in Premiere (easy enough) and key that color into the 2nd line of the lower 3rd (not so easy). I use to do this in FCP 7 by changing the colored rectangles section to alpha in the blending menu, and putting it on a video layer above the Lower 3rd title, but don't have that option here.
Any ideas? Thanks!
Ann Bens
Re: Key a different color into a photoshop title
on Feb 13, 2018 at 9:01:11 pm
If its a PS file open it from Premiere in PS and change it there.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
Anthony Vamvakitis
on Feb 13, 2018 at 9:38:01 pm
actually just checked and it's an .mov file with alpha. Anyways, it would be too time consuming to change all 60 titles like this, even if it was .psd. If it's possible to do it the way I did in FCP 7, then I can just do it once and then copy and paste the affected clip for the remainder of the lower thirds
jerry wise
on Feb 13, 2018 at 10:02:57 pm
would "change color" work ? i use that all the time.
Tony Vamvakitis
on Feb 14, 2018 at 8:07:22 pm
This seems to be the best option, but since the title fades up, I'm not sure the color picker will work until the fade is complete.
Frustrating when the newer software can't do the stuff the old software did.
greg janza
on Feb 13, 2018 at 9:52:57 pm
or make things really easy on yourself and do it in AE.
I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
- Orson Welles
Blaise Douros
on Feb 13, 2018 at 10:54:46 pm
Use the "Change To Color" effect for the most control.
