How to swap a set of MXF files for a set of quicktime?
Mark Francombe
on Feb 10, 2018 at 10:42:38 pm
Maybe the whole question is in the subject?
I have edited a few projects using MXF files direct from the camera, it worked but on my computer, was sluggish and difficult. AFter some tiesting, I discovered that converting stuff to quicktime prores worked a treat.
Some project have become worse over time, and multiple crashes.
now After my discovery, Id like to try to replace ALL the footage in the project with a newly encoded set of quicktimes...
I can right click on a single clip and select Replace footage, choose the quicktime version, but if I select the whole bin, or multiple files, the option isnt there.
All the files have exactly the same name apart from the extensions. So A010C341_1802060T_CANON.MXF has become A010C341_1802060T_CANON.mov
How can I achieve this?
Mark Francombe
Boss Creative
Transform
Eric Santiago
Re: How to swap a set of MXF files for a set of quicktime?
on Feb 10, 2018 at 11:22:28 pm
I had to trick files into switching a few years ago.
I used Resolve to achieve this.
Hope you find a way in PPro.
John Pale
on Feb 10, 2018 at 11:23:26 pm
Select the clips. Make Offline.
Then Link Media to the new Quicktimes.
If your new Quicktimes have a different audio configuration than the original media, you might have an issue...but other than that, its pretty simple.
Mark Francombe
on Feb 11, 2018 at 8:04:23 pm
Thanks, it was the "Make offline" clue that worked...
Mark Francombe
Boss Creative
Transform
