File size reduction for photo/video
Cale Henderson
on Feb 5, 2018 at 11:22:22 am
I have 43 minutes of voice over on my audio track along with a little music.
I have 3 still images spread out on my video track.
This is basically a glorified PowerPoint presentation. I'm trying to export the video in a manageable file size, but 43 minutes is pretty enormous. I have a basic understanding of long gop and how frames can reference previous frames to help with compression. I can't figure out how to lower the file size without crippling the bit rate.
Tero Ahlfors
Re: File size reduction for photo/video
on Feb 5, 2018 at 11:29:00 am
If there's nothing happening you don't need to put a lot of bit rate for the video. The encoder should use only what it needs so if you have stills it should keep the bit rate pretty low.
Cale Henderson
on Feb 5, 2018 at 11:37:18 am
I dropped the bit rate to 2 mbps. That was a little too small since there is some text on the screen... but even at 2 mbps it results in a 1.6 GB file.
Jon Doughtie
on Feb 5, 2018 at 2:16:44 pm
What wrapper and codec are you using for your final deliverable?
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
Cale Henderson
on Feb 5, 2018 at 6:31:55 pm
H.264 / MP4
