Yellow bar on top of my clips remain yellow, not green, after render.
Adam Berch
on Feb 2, 2018 at 6:03:15 pm
HI,
I'm working on Premiere Pro CC 2018
On the timeline there is a yellow bar above all my clips. When I select the whole timeline and render it, the yellow still remains there. Will that yellow go away and turn green indicating everything is rendered?
Thanks in Advance.
greg janza
Re: Yellow bar on top of my clips remain yellow, not green, after render.
on Feb 2, 2018 at 6:30:08 pm
if you're actually rendering your timeline you should see the yellow line turn to green as it renders.
My workflow is to set a work area on my timeline (with the work area bar turned on) and work area in point and out point mapped to two keys and then I map "render entire work area" to my return/enter key.
I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
- Orson Welles
Adam Berch
on Feb 2, 2018 at 9:35:47 pm
Thanks. Here is what is happening.
I select the whole timeline and then I "Render Selection." Nothing happens.
I select the whole timeline and then I "Render In to Out" (without setting In and Out Points on the timeline) It renders everything and the yellow bar on top is now Green. (It works)
Why does it not render or do anything when I "Render Selection?"
Ann Bens
on Feb 4, 2018 at 12:56:55 pm
Render selection only works on clips with red render bar.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
