Razor tool issue
Tod Geddes
Razor tool issue
on Jan 30, 2018 at 4:38:24 pm
I have the latest version and updates to Premiere Pro.
I uploaded and did a rough edit using the Rolling Edit tool.
Once the editing was approved I went back to the rolling edit points and used the razor tool to cut the excess... everything appeared fine, till I tried to put a transition over the cut point and it would place the transition on only one of the clips, not both. I checked the razor cut point and found that the footage that should have been removed was still there... I tried removing it several times, saved and rebooted the program and still the same.
Any clues??
Thanks for the assistance
Eric Merklein
Re: Razor tool issue
on Jan 30, 2018 at 6:15:55 pm
It may be easier to use keyboard commands:
1- Add edit (which actually means make a cut, or splice) where your in point and out point is located.
2- Mark the new clip
3- Extract
Never fails.
Eric
Ann Bens
on Jan 31, 2018 at 12:48:38 pm
The clip that does no contain the transition probably has no handles.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
