Creating a Multi-camera Source Sequence from a normal Sequence
Gudni Briem
on Jan 20, 2018 at 6:45:42 am
Hey - long time reader - first time poster so let me start off by professing that this forum has been a godsend in my videomaking over the past decade.
Onto to the problem which is the following;
I use PluralEyes in conjunction with my own eyes to organize clips into a synced sequence and I've trying to conform that sequence into Multi-camera Source Sequence that I can work within the Program monitor.
So does anyone know if it's possible to create a Multi-camera Source Sequence from a normal Sequence (nested or not).
Working with CC 2014
Any tips or tricks or ideas would be extremely helpful.
Herb Sevush
Re: Creating a Multi-camera Source Sequence from a normal Sequence
on Jan 20, 2018 at 4:37:03 pm
[Gudni Briem] "So does anyone know if it's possible to create a Multi-camera Source Sequence from a normal Sequence (nested or not)."
Yes it is. Here's a link to the most thorough explanation I know.
http://www.thepremierepro.com/blog-1/2015/9/2/creating-multicam-clips-in-pr...
Note that you don't have to go through all those steps - dragging your sequence onto the "new sequence" tool and then right click and choose multicam enable will do it for most uses.
I will say, however, that there's no need for Plural Eyes at all (I do have a copy.) It is much easier to use the "make multicam" feature in Ppro and you will get more audio options.
Herb Sevush
Zebra Productions
nothin' attached to nothin'
"Deciding the spine is the process of editing" F. Bieberkopf
