Import Sony camera clips into Premiere Pro CC 2015
Adam Berch
on Jan 18, 2018 at 5:26:50 pm
I am working in Premiere Pro CC 2015 on an Imac. I have clips from a Sony Camera that I need to ingest into Premiere.
How can I do this? I want to be able to pick and choose the clips I import before actually importing them.
Thanks in advance.
Eric Merklein
Re: Import Sony camera clips into Premiere Pro CC 2015
on Jan 18, 2018 at 11:29:35 pm
Hello Adam.
I use Sony cameras and importing is very easy.
After transferring all of your clips to your IMac you can either pre-select by viewing clips using VLC, and importing after that, or import everything and blow it off after viewing.
You can also pre-select by viewing from the media card from your camera first using VLC.
E
Adam Berch
on Jan 19, 2018 at 12:59:05 am
HI Thanks.
OK When I play the clips through VLC, without Premiere open the clips play fine. When I open Premiere and try to import the clips, it goes to the Beach Ball and doesn't do anything else. I always have to Force Quit Premiere.
How can I stop this from happening? All I want to do is select all of the clips, import them into Premiere and start working.
Do I need to download a Codec or something? If so, which one and where do I get it?
Thanks in advance
