Getting Prores 422 out of Premiere Pro CC?
Mark Suszko
on Jan 16, 2018 at 8:00:23 pm
Apologies from a Prem Pro noob. How do I export a Prores422 file? I don't see the option in my export dialogues.
Jeremy Mamisao
Re: Getting Prores 422 out of Premiere Pro CC?
on Jan 16, 2018 at 8:43:52 pm
When you export, under Export Settings -> Format, select Quicktime. Then under "Video Codec", Apple ProRes 422 is an option.
Ann Bens
on Jan 16, 2018 at 8:46:25 pm
Prores export is only available on a Mac not Windows.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
Mark Suszko
on Jan 16, 2018 at 9:54:12 pm
Thanks, Ann, that worked perfectly.
Greg Mattison
on Feb 8, 2018 at 8:33:26 pm
Anyone noticing that the ProRes presets from Premiere/ Media Encoder have a much lower bitrate relative to their setting that can not be changed?
For example ProRes 422 in my BlackMagic Cinema camera runs 150 mbits/sec (@ 1920 30p)
FCP output between 70 mbits/sec - 200 mbits/sec depending on ProRes LT - ProRes HQ
but...
When I output Premiere CC 2018 sequences using the ProRes 422 or 422HQ codecs the highest I can get the bit rate is 20 mbits/sec
I am confirming this through the QT7 Movie Inspector
15-20 mbit/sec doesn't seem right for ProRes, even if it was defaulting to ProRes LT for some reason, which it is not, according to the file inspector. Although the file is tagged as ProRes I'm wondering what I'm getting with these Adobe ProRes Presets.
greg janza
on Feb 9, 2018 at 7:33:29 pm
Use something else to confirm your bitrate. I just made a pro res HQ file and it was 119 Mbit/s.
I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
- Orson Welles
