Premiere 2018 audio issues
Adam McCune
on Jan 9, 2018 at 1:35:32 am
This keeps popping up and it's incredibly frustrating.
Running a trashcan 2013 MacPro
3.5ghz 6 core
64gb RAM
AMD FirePro D500 3gb graphics
macOS Sierra 10.13.2
I've noticed this problem popping up quite a lot lately. Generally, it's with MPG files, which is a part of my workflow for meetings we cover (I run a public access channel)
I import. Play the file.....no audio.
About 80% of the time, I can work around this by deleting the unused media cache and it works. if that fails, I restart Premiere. If that fails, I have to reboot.
Obviously, none of this is very conducive to a solid workflow. I actually tried switching back to 2017 (I kept both on my computer) and had the same problem. In fact, if you open both versions, you are almost guaranteed to have them both have this issue.
Anyone else having this problem? Anyone else figured this out? Please?
Writer/Radio host/Community Media Advocate
Todd Perchert
Re: Premiere 2018 audio issues
on Jan 9, 2018 at 3:19:00 pm
Are these long mpg files? I do this as well occasionally with 1 hr mpg files. Usually the audio is conforming. You should see a progress bar on the lower right of your sequence window that says conforming audio (or something like that). For mpg files, you usually have to wait until it gets all the way through the file before you can play/hear the audio. PPro has been like that for some time now. Don't think that will change with mpg files.
TC
Adam McCune
on Jan 9, 2018 at 5:38:55 pm
Yes. Generally 1-2 hours, sometimes longer. I wait until the status bar has finished before I even start bringing them into the timeline.
If the problem is muxing, how in the world do I fix this? My workflow hasn't changed in 5years, the only change has been to the updates in premiere. And the files play fine elsewhere.
