Premiere Pro is so hard to work on my MacBook!
Cihan Kurt
on Jan 8, 2018 at 11:40:17 pm
Hello to everyone! First of all I apologize to you for my bad english. About a month ago I bought a Macbook with great hopes. The only reason for this was that my old computer was now inadequate for video editing. But I am having a great disappointment right now.
First of all I want to give you all the necessary information.
Features of my computer :
MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
2.5 GHz Intel Core i7
16 GB 2133 MHz LPDDR3
Intel Iris Plus Graphics 640 1536 MB
The characteristics of the video I have organized:
1080p 60 FPS
Iphone 8 Plus
h264
The problem I am having is:
I can not even edit 1080p at 60FPS video resolution. After you start editing, the timeline begins to freeze and the frame drop color turns yellow. When I opened the activity monitor, I did not see any trouble in Ram. But I can not say the same thing for CPU. Because the percentage of Premiere Pro is 400%. The fan is almost nervous. And as I said this is not 4k image 1080p!
I have tried many solutions for this.
I'm seeing it with Apple. There are no defects in the hardware. And I tried all the ways below.
I closed the effects while editing.
I made the maximum RAM I could use from the settings.
I formatted the Macbook.
I reinstalled Premiere Pro.
I turned off Maximum bit depth and Maximum render quality.
And many more solutions I found on the internet ...
Please help me. Because I've been struggling for days and I have not found any solution.
I put photos for more information.
Project Settings:
[img]https://forums.adobe.com/servlet/JiveServlet/downloadImage/1390516/Ekran+Re...
[img]https://forums.adobe.com/servlet/JiveServlet/downloadImage/2-10088980-13905...
Premiere Pro not running CPU:
[img]https://forums.adobe.com/servlet/JiveServlet/downloadImage/1390534/Ekran+Re...
Premiere Pro Running CPU:
Premiere Pro running RAM:
Effects off and resolution 1/4:
Shane Ross
Re: Premiere Pro is so hard to work on my MacBook!
on Jan 9, 2018 at 1:02:41 am
Convert the footage you are working with to ProRes or other more friendly editing codec (DNxHD). H.264 is a tough beast to edit native, and 1080p60 H.264...that takes a LOT of system resources to decode on the fly, more than a MacBook Pro has to offer. So convert the footage to ProRes or DNxHD and edit that. You'll notice a difference.
Shane
Little Frog Post
Cihan Kurt
on Jan 9, 2018 at 12:28:52 pm
First of all thank you for your comment. I did what you said and changed the format of the video. My CPU usage has been reduced from 300% to 200%. But this time my RAM usage has increased almost 3 times. Unfortunately I keep alive Frame drop.
New format converted:
https://forums.adobe.com/servlet/JiveServlet/downloadImage/2-10090309-13909...
H264 format Ram used:
New Format Ram Used: (effect closed, resolution 1/4)
Dave LaRonde
on Jan 9, 2018 at 3:11:59 pm
[Cihan Kurt] "The characteristics of the video I have organized:
1080p 60 FPS
Iphone 8 Plus
h264"
Was this shot without using an iPhone camera control app? If not, it's probably variable frame rate video, which is not good in PP.
Dave LaRonde
Promotion Producer
Cihan Kurt
on Jan 9, 2018 at 4:56:57 pm
Yes I did not use any applications. iPhone's own camera application. Would not it matter if I use filmic pro?
Dave LaRonde
on Jan 9, 2018 at 5:35:15 pm
If you want to edit video in Premiere Pro, you should ALWAYS use Filmic Pro.
There is no excuse not to use it. If you want to use your phone as a video camera, you need to use an application that makes your phone work like a video camera, and not a device for funny cat videos.
Dave LaRonde
Promotion Producer
Cihan Kurt
on Jan 9, 2018 at 5:44:11 pm
Well ☺ Yes, I know that filmic pro is really good. I just tried it in front of you, but the same problems persist. I need very serious help in this regard. I can not understand. Not even a 4k video. only 1080p! But I can not edit the edit frame droplard. I did 1080p 60FPS video recording with Filmic Pro. Then I threw him into the computer. What am I supposed to do in this state of affliction?
Jon Doughtie
on Jan 9, 2018 at 6:00:19 pm
And the video clips are kept where?
If your video is living on the same hard disk as your OS and apps, that is a recipe for unhappiness.
I notice there appears to be nothing in your list of specs about hard disks or storage.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
Cihan Kurt
on Jan 9, 2018 at 6:10:13 pm
The application files are on the MacBook's own disk. The media files are on an external hard disk. Is there anything else you can offer besides that?
Shane Ross
on Jan 9, 2018 at 6:29:05 pm
[Cihan Kurt] " The media files are on an external hard disk. Is there anything else you can offer besides that?"
Yes. How is the hard drive connected? What kind of hard drive? Meaning is it a single, small USB 3 drive? It might be too slow for media. Is it a higher end drive that's faster and meant for video editing? Is it a single drive, or a RAID drive? 1080p60 does require higher end solutions, as it is a high data rate format
Shane
Little Frog Post
Cihan Kurt
on Jan 9, 2018 at 6:55:09 pm
I'm using this external drive right now. https://www.amazon.com/gp/product/B01N7QFZLQ/ref=od_aui_detailpages00?ie=UT... But if necessary I can get one ssd too. Could you tell me which way to follow? What is the best method for disk?
Robert Withers
on Jan 9, 2018 at 7:12:01 pm
Despite Adobe's self-promotion about working with all formats, I convert everything into ProRes to edit in PrP, including iphone footage. (That said, I've never worked with iphone 60fps, only the approximately 30fps that my old iphone generates.)
Transcoding avoids a lot of problems.
Also you can try reducing playback resolution.
Robert
Robert Withers
Independent/personal/avant-garde cinema, New York City
Cihan Kurt
on Jan 9, 2018 at 7:36:46 pm
Could you elaborate more? They have ProRes formations. Which is the best for 1080p 60 fps?
