Keep sequence attributes, but substitute new clips
chris pike
on Jan 3, 2018 at 1:59:42 am
I have a sequence for a text "slider", which I use repeatedly. The sequence contains four graphical elements, each with attributes of motion. The timing of these elements in the sequence is also important. I'd like to create copies of this sequence but with different text. However, the only way I know to do this, is to copy the whole sequence, then paste new graphical elements into the new sequence timeline, then position these elements at the correct points in time, then also copy the attributes from the old sequence to the new sequence, then delete the old stuff from the new sequence. The result is new material, but with the old attributes and timeline. Is there a faster way? Can I just copy the sequence, and then link the elements of the new sequence to different files in the project folder?
Tero Ahlfors
Re: Keep sequence attributes, but substitute new clips
on Jan 3, 2018 at 7:55:31 am
You can also duplicate the sequence by right clicking it in the project panel. You can then replace what you need in that.
chris pike
on Jan 3, 2018 at 6:19:52 pm
Nice, didn't know about this. However, it doesn't get me quite where I want to go. After I copy the sequence, it will have the previous clips in it. I'd like to substitute different clips, but preserve the attributes and the time sequencing. It would be nice if there was a command that would say, "substitute this other clip here, but keep everything else the same".
John Heiser
on Jan 5, 2018 at 11:19:50 pm
Have you tried the Essential Graphics function? You can import graphic elements (PSD, PNG, etc.), animate them, and add text, animating the text if you want, and then save the whole thing as a Motion Graphics Template. Then just drag the template from the Essential Graphics panel into your timeline and change the text. The animation will remain the same, just the text will change. The time you spend recreating your animation once will probably be much less than having to do the dance you described in your post.
https://helpx.adobe.com/premiere-pro/using/essential-graphics-panel.html
