Premiere Pro Export Estimated File Size Problem
osuran boğa
on Jan 2, 2018 at 10:57:11 am
Hi ı have a problem with exporting :
Problem : Estimated file size showed me 618 mb came out as 144 mb.
Output : 1920x1080 (1.0) 30fps ,vbr 2 , target 16.00 mbps, max 20.00 mbps, AAC , 640 kbps , 48 kHz, 5.1 (L,R,C,LFE,Ls,Rs)
Also performance on memory.
I am trying to have 1080 HD option for youtube.But export not letting me do it.I dont know whats happened it was fine.
Tero Ahlfors
Re: Premiere Pro Export Estimated File Size Problem
on Jan 2, 2018 at 12:55:03 pm
The estimate is, well, an estimation. It doesn't know if the video you're exporting needs that much bitrate and if there's something simple like text on a background it goes in a smaller space.
Jeff Pulera
on Jan 2, 2018 at 4:46:03 pm
I agree with Tero - the VBR encoding is only going to use as much bandwidth as is necessary for the scenes being encoded. If you encode using Constant Bit Rate, then it would be a bigger file. However, I never see a SMALLER file as a being a "problem". It saves space, downloads quicker, etc.
Jeff Pulera
Safe Harbor Computers
