Fixing massive green shift from LED stagelights?
Boris Dimitrov
on Dec 19, 2017 at 12:45:52 pm
Hello everyone,
I am working on a multi-camera live concert project. The project was shot on a number of different cameras.
On a few of the shot where the stage lighting is a heavily saturated purple, all of the Sony cameras have an unusable, burned out, heavily color-shifted image (3 cameras in total). The issue only happens with this particular color of the stage lighting and only on the Sony cameras (please see comparison below). Shadows and midtones show up as blueish, while the highlights around the projectors themselves show up as this super weird saturated green that is very different than any light that was present in the actual scene.
One of the Sony A7s II cameras:
https://drive.google.com/open?id=1odiukE00TABujwWUtYlqn0jWbFk4xLp6
The other Sony A7s II:
https://drive.google.com/open?id=1YXPkXqyuS_vc5Kj0m0wMY8CyGW5yEVM4
A Sony A65:
https://drive.google.com/open?id=1qu26vkMEFXQRyqdB_pl0z7mBFeIUpHsS
For comparison of what the actual colors looked like (and much more decent falloffs), here is the Canon 70D:
https://drive.google.com/open?id=1Ijafq0_zFmPzsktMUCBiVfWRL5IBX2PH
And a PTZ Optics live streaming camera:
https://drive.google.com/open?id=1Ld9sTt10sVncYV6LTf9F2yZ1Pd0CXtTB
White balance & tint hardly make any difference. I've tried messing around with color wheels, RGB curves, channel mixers and every other color adjustment I thought of, but I cannot find anything that shifts the weird green without making all the other colors weird or makes any improvement on the horrible falloff around the stage lighting.
Can anyone think of anything else i can try and, probably even more importantly - what might be causing this issue? Any tips will be greatly appriciated!
Alan Okey
Re: Fixing massive green shift from LED stagelights?
on Dec 19, 2017 at 10:50:08 pm
This could be easily corrected in DaVinci Resolve. Try the hue vs. hue curves.
Boris Dimitrov
on Dec 20, 2017 at 11:16:07 am
Hi Alan and thanks for the tip!
I envy your skills if this seems like an easy fix! ☺ I am a Premiere Pro/Lumetri/Colorista user and dont have any experience with DaVinci Resolve, but I'l definitely either try and find a corresponding hue vs hue curves tool thats available in Premiere or possibly even try out DaVinci itself.
Alan Okey
on Dec 20, 2017 at 8:19:06 pm
[Boris Dimitrov] "Hi Alan and thanks for the tip!
I envy your skills if this seems like an easy fix! ☺"
Thanks, but my skills aren't really responsible for the ease of the fix. It's just a question of selecting the right tool for the job!
Here's a screen shot of the hue vs. hue curve correction in Resolve, comparing your Canon still to the corrected Sony shot. It only took a few seconds to get this result, and I'm sure with some finessing, it could be even better.
https://drive.google.com/open?id=13KGTrTaBvh1csLyi0oQfRW-HXgAKKPPD
Boris Dimitrov
on Dec 20, 2017 at 8:53:16 pm
Whoaah! You should have seen the look on my face, heh.
I think I should in theory be able to get a similar result using the HSL Secondary tool in Lumetri Color, but my last attempt was.. less than stellar. Relatedly, think you might slightly be on the modest side regarding your skills/feel for how to do the right edit ☺
I'll definitely give it another shot now that you've shown me its possible, if i am able to get it even close to what you have achieved, I think i'll will have pretty much solved my problem!
Massive thanks once again for essentially shining a light in the tunnel!
Boris Dimitrov
on Dec 20, 2017 at 9:43:13 pm
Just played around with HSL Secondary some more and also read into how the hue vs hue curve works in DaVinci.
From what I am able to work out right now, the HSL Secondary is alot less versatile in selection/correction in the way it is built.
You basically make a selection in hue/sat/lum with 'rolloffs' on each side (is it me or is there no way to make the two 'rolloffs' on each side of the selection a different length?).
You then apply global corrections (by global i mean they apply to the whole selection, falling off gradually where those 'rolloffs' of the selection are) in hue/sat and other adjustments.
For comparison, if I understand it correctly, the hue vs hue curve in DaVinci allows you to make different adjustments to the different hues that comprise the selection with very precise control. You can, as Alan has done, shift greens alot, cyans a little less, and blues ever so slightly.
That seems to be precisely whats needed for the edit I need to do on my footage, and I can't seem to find a way to do it with Lumetri as of right now.
I did download DaVinci, though.. it's getting late, but ill dive right in tomorrow! :)
Alan Okey
on Dec 20, 2017 at 10:16:05 pm
[Boris Dimitrov] "the hue vs hue curve in DaVinci allows you to make different adjustments to the different hues that comprise the selection with very precise control. You can, as Alan has done, shift greens alot, cyans a little less, and blues ever so slightly.
I did download DaVinci, though.. it's getting late, but ill dive right in tomorrow! :)"
Resolve is a great tool to have in your tool kit, and as the free version is extremely capable, there's no reason not to dive right in. In addition to being a world-class color application, Resolve is also a great Swiss army knife that is useful for many non color-specific tasks such as transcoding dailies, adding window burns for timecode or other data, and syncing dual system sound. Since it greatly leverages GPU processing, it can perform some tasks much faster than other applications.
Enjoy exploring Resolve!
