Wav Audio Drifting in Multicam sequence in Premiere Pro CC 2017
Mark Jackson
on Nov 30, 2017 at 10:17:05 pm
I ran into a problem using a Tascam DR 40 WAV file. I recorded an hour and a half concert at 48000Hz 16bit. I also had all the camera’s audio set at 48000Hz 16bit. I went ahead and edited the whole concert in Premiere Pro’s Multi Cam mode using the best camera’s audio. When I tried synchronizing the WAV file from the Tascam DR 40 with the audio in the timeline, everything is in sync for half the show. However, the audio from the WAV file drifts the second of the show.
Has anyone experienced this problem? If so, how did you solve it?
Mark D. Jackson
