UPDATING OPERATING SYSTEM and/ or PP VERSION MID PROJECT. Bad Idea ?????????
Karen Yarosky
on Nov 28, 2017 at 3:00:34 pm
Hello all. I am mid way through editing a large documentary project and my MacBook Pro has started to have different issues (not with PP but other software issues). I have been advised to wipe the computer clean and install an updated operating system (I am behind, presently on OS X Yosemite ... they want to start with El Capitain). Here are my questions: I am aware that changing anything during a project can wreak havoc (which is why I have been scared to change anything ... and am working on a very long project that still has many months to go). Thoughts on whether El Capitain will make a difference this late in the game in terms of interfacing with Premiere Pro (I have read that there are a lot of issues with High Sierra so not touching it ...). ALSO ... I have not done any updates to PREMIERE PRO since I started my project so I am worried that if I have to reinstall all my Adobe applications after I wipe my computer that I will have glitches if I am reinstalling a different version of PP. Yes I am paranoid .. or am I ???? What are your thoughts - for those that have been through this before ..... They do not want me to reinstall with Time Machine so I cannot just pick up where I left off. Is it possible to download an older version of PP? And if so how do I find out exactly which version I am using (when I "get info" on my current PP application it just says Adobe Premiere Pro CC 2017 - I am not sure which version this is). Many thanks and apologies for a lengthy email.
Chris Wright
Re: UPDATING OPERATING SYSTEM and/ or PP VERSION MID PROJECT. Bad Idea ?????????
on Nov 28, 2017 at 6:15:51 pm
your luts will randomly change, color correcting will be flat wrong, effects will be reset, media cache will be incorrect, files will unlink, and that's just for starters. adobe does not make stuff backward compatible.
Shane Ross
on Nov 28, 2017 at 7:15:00 pm
OK, if you must update, then do the following:
CLONE YOUR CURRENT HARD DRIVE. Get an external hard drive...get CARBON COPY CLONER...and clone your current OS drive to this external. In case ANYTHING goes wrong or haywire with the update, you can use this clone to go back to the working system you had before.
Shane
Little Frog Post
Karen Yarosky
on Nov 28, 2017 at 10:03:00 pm
Many Thanks to all of you for the input. I will keep going with what I have and deal with software issues until the doc is done. MUCH APPRECIATED! Cheers!
