Toggle proxies
Vasco daNeva
Toggle proxies
on Nov 17, 2017 at 3:43:17 pm
I finished a 4K project using proxies and encoded it. Only after I erased everything did I realize that before encoding I had forgotten to toggle the proxies icon back to 4K. In other words the icon was still blue when I sent it to Encoder. My question is What did I make? A proper 4K clip or a 4K clip from 720p proxies (and therefore a fool of myself)?
Vasco
Tero Ahlfors
Re: Toggle proxies
on Nov 17, 2017 at 5:34:47 pm
Exports shouldn't use proxies.
Vasco daNeva
Re: Toggle proxies
on Nov 18, 2017 at 11:44:44 am
I thought so too but on one tutorial a guy said you should turn off the Toggle proxies icon. I didn't, hence my question.
Tero Ahlfors
Re: Toggle proxies
on Nov 18, 2017 at 12:20:52 pm
Have you tried reading the manual?
https://helpx.adobe.com/premiere-pro/kb/ingest-proxy-workflow-premiere-pro-...
Vasco daNeva
Re: Toggle proxies
on Nov 18, 2017 at 12:49:08 pm
You mean where it says: • When you render Previews, Export Media or use certain Analysis effects (Warp Stabilizer, Rolling Shutter Repair, Morph Cut), Premiere Pro always uses and displays Full Res, regardless of the Toggle/Enable Proxies setting. The only exception is when you have Offline Full Res, but Proxy is Online, then Proxy is used.
I read it but like I wrote earlier... there was this tutorial... Anyway, my question was answered. Thank you.
Peter Northall
Re: Toggle proxies
on Nov 18, 2017 at 12:42:32 pm
The toggle proxies button makes no difference to exporting. Full res is always used (as long as it's online).
Vasco daNeva
Re: Toggle proxies
on Nov 18, 2017 at 12:50:08 pm
Thank you very much! What a relief.
