Color difference source monitor and program monitor
Bella Gavelin
on Nov 14, 2017 at 10:41:17 am
Hi everyone,
I am in a bit of a hurry here so have not started troubleshooting that long ago. Does anyone have a quick answer for this? I want it to look like in the source monitor. What setting is wrong and where?
bella
Tero Ahlfors
Re: Color difference source monitor and program monitor
on Nov 14, 2017 at 10:55:35 am
Computer specs? Footage specs? Sequence settings? Are you using software or GPU rendering? Any effects on clips and/or adjustment layers?
Bella Gavelin
on Nov 14, 2017 at 1:01:04 pm
Mac Pro 2013
3 GHz 8-Core Intel Xeon E5
64 GB 1866 MHz DDR3
AMD FirePro D500 3072 MB
Sierra 10.12.6
Adobe Premiere Pro CC 2017
Apple pro res mov files.
No adjustment layers or effects. The files are graded and coming from a Davinci export. Looks correct in the source monitor.
Sequence settings : Editing mode: arri cinema.
GPU rendering.
bella
Tero Ahlfors
on Nov 14, 2017 at 2:06:01 pm
What you could try:
-Turn off the GPU rendering
-Make a new sequence with custom settings
-Make a new project
-Trash your preferences
Chris Wright
on Nov 14, 2017 at 3:01:09 pm
Check your Master Clip Effects.
Todd Perchert
on Nov 14, 2017 at 8:56:48 pm
So if you take your source footage in the bin, drag it to new item (lower right corner of bin), the program window opens looking that much brighter?
TC
