Source Track Indicator/Patch Toggle disappears from my project. PremierePro CC 2017
Jan Du
on Nov 13, 2017 at 3:00:39 pm
Hi Guys,
Okay, so I can't seem to toggle the source track indicator labeled V1(depending on the video track). It is used to toggle the video track that you'd like to paste a clip to. In my case, to activate V1 to cut my MultiCam sequence. I have scanned my toolkit and preferences to see if it is disabled. What is also strange is that issue does not occur in other projects that I have done without MultiCam.
To add, I have recently migrated to another workstation and updated Premier from 2015 to 2017.
Any help would be dearly appreciated.
Ann Foo
Re: Source Track Indicator/Patch Toggle disappears from my project. PremierePro CC 2017
on Nov 14, 2017 at 4:54:33 am
Source track indicator (V1) will disappear if you don't have any V1 media in your source window....
So considering you're trying to edit with a muticam sequence... perhaps your locator is at a part of the multicam sequence where there is no V1, (only V2 and/or sound). Try scrolling to a bit in the multicam sequence where there is V1 media. Or, load up a video only track into your source monitor and see if your V1 toggle comes on.
