Scaling copy bug
Oliver Peters
Scaling copy bug
on Nov 11, 2017 at 10:46:06 pm
I frequently use oversized clips in my sequences, like 4K shots inside 1080 timelines. I normally use "set to frame size" when I edit, so a 4K clip has a 50% value. If I need to punch in, then the scale might change to 75% with a slight X/Y position offset. When I copy-and-paste clips between sequences, this type of sizing information is lost. Generally position information is retained, but the scale value is wrong. Are others seeing this bug? It's been there for several CC versions. Any suggestions?
- Oliver
Oliver Peters - oliverpeters.com
John Pale
Re: Scaling copy bug
on Nov 12, 2017 at 1:03:48 am
Yes.’ The only solution is to turn off auto set to frame size
Oliver Peters
on Nov 12, 2017 at 1:21:59 am
[John Pale] "Yes.’ The only solution is to turn off auto set to frame size"
Do you mean when you make perform the paste function? I know you mean in general, but would it work if only off when you paste?
- Oliver
greg janza
on Nov 12, 2017 at 3:10:56 am
I have the same problem and it 's quite an annoyance. If the solution is to turn off auto set to frame size that's great but where is that setting now in Premiere?
I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
- Orson Welles
John Pale
on Nov 12, 2017 at 6:52:25 pm
Not in front of my system now, but I think it’s in Preferences/Media
Herb Sevush
on Nov 13, 2017 at 1:31:53 am
[greg janza] "I have the same problem and it 's quite an annoyance."
Yes, a big time PITA.
Herb Sevush
Zebra Productions
nothin' attached to nothin'
"Deciding the spine is the process of editing" F. Bieberkopf
John Pale
on Nov 12, 2017 at 6:58:09 pm
If the setting is turned off, paste works correctly.
If it is on, motion settings don’t get included in pastes.
Oliver Peters
on Nov 12, 2017 at 7:10:24 pm
Thanks.
- Oliver
