How do you shorten over extended word in dialogue?
Olivier Prudhomme
on Nov 10, 2017 at 12:00:35 am
I am working on a documentary and the interviewee drags the end of some words like for ex:
We went to theeeeeeeee beach
She does that a lot and I need to shorten.
Basic fading isn't working well.
Keyframing either...
ANy idea / trick?
Los Angeles - TV Promo Editor - FCP - AVID
Massimo Alberto Croce
Re: How do you shorten over extended word in dialogue?
on Nov 10, 2017 at 6:44:50 pm
You can try a fade with a short reverb and playing with dry\wet on the effect.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
on Nov 10, 2017 at 6:46:24 pm
The effect must be track effect not clip effect
Olivier Prudhomme
on Nov 13, 2017 at 12:52:46 am
[Massimo Alberto Croce] "playing with dry\wet"
not familiar with this... Is it the name of effect? Couldn't find it.
on Nov 10, 2017 at 11:46:13 pm
Or maybe cut in between the start and end of the eeeeeee so it can finish naturally
John Pale
on Nov 11, 2017 at 3:40:48 am
If you send the clip to Audition, you can use its time stretch feature to play with this and see if you can improve it.
Dave LaRonde
on Nov 12, 2017 at 12:29:30 am
In other words, it ain't easy to fix. Or fast.
Dave LaRonde
Promotion Producer
andy lewis
on Nov 12, 2017 at 3:19:43 pm
Finding an example of a short "the" or "to the" from somewhere else in the interview and editing it in is probably easier than adjusting what's there. With such a short sound you might even get away with using someone else's voice.
Olivier Prudhomme
on Nov 13, 2017 at 12:54:43 am
I tried but voice tone is too different
John Pale
on Nov 12, 2017 at 7:03:43 pm
“In other words, it ain't easy to fix. Or fast.”
Its not bad, really.
Comparing the time wasted to find a similar sound and trying to cobble something together with less than satisfying results to using the right tool for the job.
Olivier Prudhomme
on Nov 13, 2017 at 12:54:06 am
I'll explore that
thx
