I'm freaking out! Quality dropped down very badly!
Etienne Visora
on Nov 9, 2017 at 9:37:27 am
Hello to everyone!
This morning, when I opened a project I'm working on Premiere Pro, I had a bad surprise.
Basically, almost every clip (which are so many) that I keyed to remove the green screen with Primatte Keyer, now have some green pixeled things in the background.
I don't think it's a keying problem (as you can see in the image below, before this problem the result was cool).
I seriously don't know how to fix it without doing it all over again (which would kill me, as I have a strict deadline)
Another thing I thought it could be is related to the new version of Premiere Pro, CC 2018.
But as I remember, I already opened this project with it, and it did not gave me this problem.
I will venerate whoever can help me with this!
Jon Doughtie
Re: I'm freaking out! Quality dropped down very badly!
on Nov 10, 2017 at 3:34:00 pm
For starters, have you tried clearing cache files? If you have upgraded to 2018 mid-project, weird things with cache files can happen. Delete them all, this will force the application to remake them.
Also if this is a mid-project upgrade, you may need to delete FX on the file and try doing it form scratch. Make a sequence copy so you can leave your original alone, in the event someone has a simpler fix.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
