Premiere won't start without closing in task manager
Brandon Little
on Nov 7, 2017 at 4:00:21 pm
Title says it all, but this problem persists into the 2018 release of Premiere Pro CC. Launching it from Start doesn't work until I go into task manager and close it first.
Clearly, Premiere doesn't fully close when it should - this has been a long-standing issue through many versions of Premiere and it's truly confounding as to why.
Any thoughts / workarounds? Having the same issue?
Windows 10, 64bit
Premiere CC 2018 (and earlier)
greg janza
Re: Premiere won't start without closing in task manager
on Nov 7, 2017 at 9:13:06 pm
Unfortunately your problem is localized. I'm on Windows 10 also and I've never run into that issue. the firfst steps I'd take is to do a clean install of premiere and any other Adobe programs.
I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
- Orson Welles
Brandon Little
on Nov 8, 2017 at 9:22:56 pm
Thank you for the suggestion.
Michael Sacci
on Nov 19, 2017 at 2:54:13 pm
I have the same issue so you are not alone. I'm on Windows 10 and PP 2018.
I may do a reinstall as suggested above after I finish the current project.
