multicam workflow
micheal youssef
multicam workflow
on Nov 2, 2017 at 1:44:28 pm
hello
i'm already created project for jazz festival which shooted by four cameras with separate audio came from main mixer, and i use pluraeyes to sync it then i discover that if i want to use multicam options i must use it from beginning but now i can't, is there any way to make this sequences to multicam sequences
micheal youssef
James Barry
Re: multicam workflow
on Nov 2, 2017 at 4:44:50 pm
Nest the stacked sequence, right-click on the nest, go to Multi-Camera, ENABLE. You should be able to bring up the different cameras now by double clicking the Multi-Cam nest.
