Creating Proxies from Sony FS5 4K footage
Mark Krueger
on Oct 26, 2017 at 12:00:29 pm
When I try to create a proxy file for FS5 Sony 4K clip I get an error message regarding the 4 channel audio being not compatible. Therefore it does not generate a proxy file. Any ideas here?
Johnny H
Re: Creating Proxies from Sony FS5 4K footage
on Oct 26, 2017 at 2:18:43 pm
Mark,
I have not had this issue but below is a link to the setting I have had success with when making proxies for FS5 4K. This is using the ProRes 422LT codec.
Ingest Preset Proxy ProRes 422 LT for F5 (4096 X 2160) to 1024 X540 Ingest.epr
https://www.dropbox.com/s/ps5154dt04fn92g/Ingest%20Preset%20Proxy%20ProRes%...
John Hudson
Bright Light Visual Communications
greg janza
on Oct 26, 2017 at 5:22:39 pm
Your proxies have to match the 4k files exactly with regards to audio channels. If you have 4 channels of audio on the 4k files then your ingest setting must also be four channel. When I made proxies I had to create custom ingest presets with correct audio channel information because the default ingest options didn't have 4 channel audio. You create the custom ingest presets in Encoder and then export the preset to a location that you can steer to in the proxy settings pop up in premiere.
I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
- Orson Welles
Mark Krueger
on Oct 27, 2017 at 3:05:29 am
Thanks Greg. I will give that a try!
Mark Krueger
on Oct 30, 2017 at 2:42:32 pm
Greg... I cannnot find where I can create custom presets for 4 channel audio... Can you give me a few directions or send some links to good tutorials on this. Thanks Mark
greg janza
on Oct 30, 2017 at 3:52:26 pm
https://blog.frame.io/2017/03/20/premiere-pro-proxies/
- Orson Welles
