What DNxHR codec should I use for FS7 footage
Allard DePallerd
on Oct 23, 2017 at 1:13:53 pm
hi guys,
I want to convert my FS7 UHD footage to MXF DNxHR, which is more friendly for my system. So i want a lossless/lossy conversion.
However, there are so many options to choose from. Im not sure which one I should pick to make sure I dont loose any quality.
These are the specs from my footage:
bitrate: 490 mb/s
4:2:2
10 bit bit depth
4096x2160 pixels
So i was thinking about the DNxHR HQX codec.. Would that be the right one?
And it appears streamclip can't do this for me.. so should i just adobe media encoder..or resolve? thanks
Dmitry Kuznetsov
Re: What DNxHR codec should I use for FS7 footage
on Oct 27, 2017 at 6:59:31 pm
DNxHR HQX is a good choice I use it in my workflow very often, but be aware that Adobe Premiere and Adobe Encoder doesn't work correctly with anything more than 10 bits. I prefer to encode in after effects everything that needs color management and anything that have more than 8 bits.
More here:
http://wolfcrow.com/blog/how-to-handle-bit-depth-in-adobe-premiere-pro-afte...
Resolve should works fine.
Color Grading Specialist / DI Colorist / DaVinci Resolve Colorist
For business inquiries:
http://contact.photodmitry.com
Allard DePallerd
on Mar 30, 2018 at 11:40:04 am
I forgot to thank you for your reply!
Thanks again!
