Output to TV monitor iMac 2017 - Premiere Pro
Ronnie Kelly
on Oct 23, 2017 at 1:12:21 pm
Hi all,
We're currently looking at getting a client monitor hooked up in one of our edit suites and I'm struggling to find the right information online.
Our current set up is a 5K 27in iMac (2017) which has a second display monitor, connected via the display port and a USB-c adapter.
Does anyone know how we can get a 3rd screen in the edit, which will just have the playback from Premiere Pro in it? Rather than it being a desktop display/mirror image.
All advice is welcome! Thanks in advance.
Tero Ahlfors
Re: Output to TV monitor iMac 2017 - Premiere Pro
on Oct 23, 2017 at 6:02:39 pm
Get an I/O device from AJA or Blackmagic Design. If you're using Resolve and you want to monitor that you'll want a Blackmagic one. There are USB 3 and Thunderbolt devices available.
Ronnie Kelly
on Nov 3, 2017 at 12:44:21 pm
Thank you kindly! Sorry for the delay in response.
andy patterson
on Oct 23, 2017 at 6:29:57 pm
You can use a 3rd computer monitor or you can use a broadcast compliant monitor. If you want to output to a broadcast compliant monitor the BMD Intensity Shuttle works good if you use HDMI or component. If you need SDI you will have to spend a little more money. Not sure if you want to use a computer monitor or broadcast monitor. If you edit any interlaced video the Intensity Shuttle is money well spent. Interlaced video never looks that good on a computer screen.
Ronnie Kelly
on Nov 3, 2017 at 12:45:35 pm
Thanks Andy. That's really helpful.
