Audio crackles with multiple layers.
John Davies
on Oct 20, 2017 at 9:12:11 am
Just stumbled across a new issue in Premiere CC 17 (11.1.2)
Whenever I have more than one audio track running, I get a crazy crackle sound. As soon as it's back to down a single track, the crackle finishes. Also happens with Constant Power fade between tracks on the same layer.
The audio is coming from a multi-cam sequence. Could this be the root of the issue?
Has any one had anything similar before? Thanks in advance!
Eric Merklein
Re: Audio crackles with multiple layers.
on Oct 20, 2017 at 1:09:34 pm
Hi John.
Could it be that when you have 2 tracks playing at the same time the audio level hits the roof and the crackling is actually distortion?
Just a thought.
E
John Davies
on Oct 20, 2017 at 1:46:48 pm
Hi, I think I found the problem.
One of the 12 multi-cam tracks had 4 layers of audio. 3 were muted and 1 was the main audio for the edit. I deleted the muted layers just to tidy the project up a bit and it seems to have stopped. Hopefully that was the cause of the problem.
