Transitions
Ronda Sanford
Transitions
on Oct 19, 2017 at 3:30:39 am
I added transitions between pictures. I find that all of them "bounce" as the transition begins, except for the cross dissolve transition. Is there a way to correct this?
andy patterson
Re: Transitions
on Oct 19, 2017 at 4:26:22 am
It sounds like it might be a bug.
Ricky Barrow
Re: Transitions
on Oct 19, 2017 at 10:25:34 am
Possible solution - If pics have keyframe moves then after applying transitions you'll need to go to each pic and pull keyframes to start and end of transitions.
Ricky
Eric Merklein
Re: Transitions
on Oct 19, 2017 at 1:19:46 pm
Do you still get the bounce after rendering?
Ronda Sanford
Re: Transitions
on Oct 19, 2017 at 6:38:08 pm
Actually, it didn't start doing that UNTIL I rendered it...
