import the .mts into PC
COW Forums : Sony NXCAM
jun jun
on Jan 22, 2015 at 4:17:36 pm
Hello.How do you import the .mts into PC from a SD card? Sony playmemories said it can not recognized the videos when i select the SD card. So, I can only use Content Browser 2 ? Thank you!
Ian Cook
Re: import the .mts into PC
on Jan 22, 2015 at 6:28:05 pm
Play Memories should see it but it is hard to say for sure without knowing which camera you are using. At the very least, copy the AVCHD folder from the card and you will have everything you need. Recent versions of Avid, Premiere and FCP all support AVCHD import without any additional plugins.
