NX3 Questions
COW Forums : Sony NXCAM
Rick White
NX3 Questions
on May 27, 2014 at 3:27:26 am
I have had the camera for a couple of months now. First issue. I removed a card after filming. I put it back in to view the clips. I could see the clips but there was no audio. Yes volume was turned up. What happened? Second issue. I am using Premier Pro CC to edit. I'm importing using the media browser going to the streaming folder to see the clips. For some reason the clips in the project panel have different file names but are of the same clip. For example a clip name 00003.MTS and 00004.MTS will be the same footage. This is a consistent occurance. I checked the recording settings. I am using one SD card in slot A.
Rick White
Oelridge Video
Bernhard Walzl
Re: NX3 Questions
on Aug 18, 2014 at 4:56:22 pm
I am not sure if you have found the answer for your questions already, but the problem with Premiere is not a problem but a feature: Spanned clips will appear merged under the same clip name.
I don't know what happened with your audio. have you found out already?
