Sony HXR-NX3D1E: Right eye out of focus
COW Forums : Sony NXCAM
Jelle Van Lysebettens
on Apr 25, 2014 at 11:33:13 am
As said in the title. When I switch to the 3D-mode on the Sony HXR-NX3D1E, the right eye seems to be out of focus. I've searched for a manual but have found none on the internet.
Does anyone know how you can adjust one lens so the 3D is sharp again?
Thank you
Jelle
Veselin Malinov
Re: Sony HXR-NX3D1E: Right eye out of focus
on Jun 30, 2014 at 12:44:22 pm
Hi, I have HDR-TD10 (same electronics and lenses as HXR-NX3D1), which has a similar problem with the right lens. Left lens (MAIN lens) do focus, but right(SUB lens) is out of focus (if you look in the direction of shooting) When shooting in 2D, image is good (then work only left (MAIN) lens), but in 3D image it's not good .
Function "Auto 3D lens adjust" from the "Camera Settings" menu was made for this setup. But I can't adjust it. I call the local Sony service, but still no answer. What happens to you?
on Jun 30, 2014 at 1:19:01 pm
I've tried the "auto adjust" but the problem was not solved. There was small damage on the lenscap so i supposed the someone from the company dropped it by accident. Finally I did send it to repair-company and they said that one of the lenses was moved possibly by a shock, so the cost for repair was 400 euros.
J
