Recording issue on NX5U (pink line across footage)
COW Forums : Sony NXCAM
Andrew Cagle
on Feb 4, 2013 at 5:47:32 pm
The company I work for uses a Sony NX5U as one of their field cameras. I shot footage of a basketball game on Saturday, and when the footage played back in the computer a flashing pink line appears across all of the footage, in the lower third of the screen.
Footage was recorded on multiple SD cards and shows up in on-camera playback, in CS5.5, and in the final exported version. Early game footage, however, does not contain the line. I have checked all the settings and tested different SD cards in both card slots and encountered the same issue.
I am lost. Anyone else run into this?
john lenihan
Re: Recording issue on NX5U (pink line across footage)
on Feb 4, 2013 at 6:21:19 pm
I have never seen nor heard of this issue before.
However, looking at your screen shot, it looks to me that it is one of two things.
1. A faulty SD card or card slot driver.
2. A sensor with one failed row.
It sounds like you have eliminated all variables for the first possibility, that only leaves the second.
I would call Sony support and once you talk to a tech, send him the pictures.
There is a strong possiblity this will have to be sent in to Sony for repair.
Actually, there is one other possibility. Early on (First year made) in NX5Us history, they found a software bug that caused recording issues. You could try the sony website, check the latest version of firmware. Then compare it to yours.
John
John Lenihan
LeniCam Video Productions
http://www.lenicamvideoproductions.com
Andrew Cagle
on Feb 5, 2013 at 3:26:26 pm
We are pretty sure this isn't a firmware. The sensor makes the most sense. Trying to get a repair estimate from Sony. Continuing to do some more research. What is very unclear is how it happened. Then again, technology doesn't work perfectly forever.
Thanks for the help, John.
john lenihan
on Feb 5, 2013 at 3:48:11 pm
Keep us informed on what you find out.
John
John Lenihan
