How to Fix Bad Pixels on a FS-100?
COW Forums : Sony NXCAM
Thomas Hughes
on Oct 18, 2012 at 10:44:32 pm
I've got an FS-100 and there are two spots in the picture. They're not the lenses so I'm thinking perhaps they're bad pixels. With my PDW-F350 cameras, if you have a bad pixel, you black balance a few times and it fixes them. Is there a similar fix for the FS-100? Thank you.
Thomas H
Ian Cook
Re: How to Fix Bad Pixels on a FS-100?
on Oct 18, 2012 at 11:25:12 pm
Same procedure but on the FS100 you access from Menu-->Camera Set-->Auto Black Balance. Do this 5-6 times after the camera has been powered on for at least an hour..
Sam Angello
on Jul 6, 2017 at 4:08:40 am
Here's a tutorial that walks you through fixing a Stuck Pixel and black balancing your camera. Hope this helps
Sherman Bahr
on Jul 19, 2017 at 6:47:03 am
If you are referring to the Sony NEX-FS100, then hot pixels could electronically be remapped. You typically do not have to have the sensor replaced. If you would like more details on this you could give me a call.
...Sherman 888-283-2228
Sony And Canon Prosumer Mini DV Camcorder Repair Free Estimates. http://www.VideoOneRepair.com 888-283-2228
