Spanning recording over two sd cards
COW Forums : Sony NXCAM
Mark Gilmour
on Jul 9, 2012 at 1:04:24 am
I own a Sony NX5U camera and love it. However, I have recorded events that span across two sd cards. The video never loses a frame during the span but the audio loses 28-29 frames at the very end of the first card immediately before the span. Is anyone familiar with this and is there a solution? Thank you for your help and response.
john lenihan
Re: Spanning recording over two sd cards
on Jul 9, 2012 at 12:39:44 pm
Mark,
Are you using the Sony provided Content Management Utility to bring the files to your computer?
I had audio drops at the file closure points when I tried to use a different method, but not when I use CMU software.
JOhn
John Lenihan
LeniCam Video Productions
http://www.lenicamvideoproductions.com
Ian Cook
on Jul 9, 2012 at 1:13:07 pm
CMU will concatenate the files into one clip with no dropouts
Mark Gilmour
on Jul 9, 2012 at 4:10:21 pm
Hi, Thank you guys for your responses. I have the CMU disc but it says it is for PCs working with Windows programs. I use Final Cut Pro 7 and log and transfer works fine except where the spanning from card A to card B takes place. That is where the audio only loses the frames.
