NeoScene wont covert audio from Sony NX5U
COW Forums : Sony NXCAM
john lenihan
on Apr 11, 2010 at 6:06:18 pm
I recenty bought a pair of Sony NX5U cameras and did a shoot in AVCHD.
I Have been having a terribly slow time editing in Vegas 9.0C with Quad Core Pentium.
Reading this forum, the collective suggestion was to try Cineform Neoscene.
I downloaded the 7 day trial yesterday, and it converts nicely, but with no audio.
When I check the log in NeoScene, it says that no audio was detected.
The audio on these cameras is linear PCM.
I retried this a dozen times, playing with the few neoscene settings, but no difference.
I can drag the AVCHD files right into vegas, and it sees the audio, its just slow to preview.
Andy ideas?
John Lenihan
LeniCam Video Productions
http://www.lenicam.com
John Lenihan
John Rofrano
Re: NeoScene wont covert audio from Sony NX5U
on Apr 11, 2010 at 7:08:29 pm
Does NeoScene support NXCAM? Possibly not since it brand new. I would contact Cineform and see what they say.
~jr
http://www.johnrofrano.com
http://www.vasst.com
john lenihan
on Apr 11, 2010 at 8:18:16 pm
Might you have a short clip of avchd that I can download and try. I want to make sure it is not operator error.
John
John Lenihan
john lenihan
on Apr 25, 2010 at 5:13:53 am
OK John,
I have been working with a great tech support at Cineform.
I sent him a sample clip, they replicated the problem, and sent me several step procedure to fix it.
Now, I am trying to start with a 3 hour continuous shoot composed of a dozen small files that I would like to both concatenate and convert with Neoscene.
The tech said Neoscene can not concatenate, but I could use Sony Vegas to point to the Neoscene encoder, and both convert and concatenate. He did not know how to do that however, do you?
John Lenihan
John Lenihan
Scott Gifford
on Jul 8, 2010 at 11:03:37 pm
Trying to convert AVCHD files from my NXCAM with Neo Scene, video converts however audio does not convert. After reading this thread and others, has anyone discovered a fix?
Scott Gifford
Scott Gifford Studios
john lenihan
on Jul 8, 2010 at 11:19:57 pm
Scott,
Call the cineform support desk. He was very helpful for me, and it was while I was still using a trial version. ( Which I did purchase once it worked).
That is what I did, and the tech walked me through a bunch of settings to finally get it to work. I can't remember what I did. I didn't write it down, I just followed his instructions.
It had something to do with the codec registering properly with windows in the windows registry.
John
John Lenihan
Scott Gifford
on Jul 9, 2010 at 10:05:44 pm
Here's the FIX! This is from Jake at Cineform:
Here's what you need to do.
Browse to the following folder:
C:\Program Files\CineForm\NeoScene\
or if you are running a 64-bit OS:
C:\Program Files (x86)\CineForm\NeoScene\
Then double click on the file called, ;mc_dec_mpa_ds.ax'.
If windows asks you how to open the file, browse to:
C:\Windows\System32\
and select 'regsvr32.exe'
You should get a message saying that the file successfully registered.
Then try converting again and you should have audio.
Scott Gifford
john lenihan
on Jul 10, 2010 at 2:29:02 pm
Scott,
Thank you for taking the time to write down and post the instructions for all of us!
John Lenihan
John Lenihan
