Arri Alexa ProRes 4444 with time code to be transcoded. Need guide lines :)
COW Forums : ARRI
viking jonsson
on Oct 26, 2011 at 9:46:41 pm
Hello,
I'm working on a project with Arri Alexa ProRes 4444. I need to transcode the files for the editor to be able to edit on her laptop.
In production we use time code to synk sound and video, can I transcode the ProRes 4444 to ProRes (Proxy) or LT in MPEG Streamclip with out losing the timecode to sync with.
I haven't worked on any project that uses time code before.. We are using Final Cut 7.0.
Thank You!
Bouke Vahl
Re: Arri Alexa ProRes 4444 with time code to be transcoded. Need guide lines :)
on Nov 11, 2011 at 1:46:42 pm
You could media manage in FCP, that would retain timecode/reel info.
Otherwise, contact me directly and i'll write something custom that saves the TC in a small database, and will apply it on the new clips.
(see my site for contact info)
Bouke
http://www.videotoolshed.com/
smart tools for video pros
Sidharth Meer
on Dec 9, 2011 at 12:04:47 pm
If you have a compatible system you can use Davinci Resolve lite to make ProRes Proxy files of all you data while retaining timecode and reel information. It is very easy.
Sidharth Meer
Post Production Supervisor @ The Bridge
