check the gate
COW Forums : ARRI
todd mcmullen
check the gate
on Jan 11, 2011 at 1:34:59 am
I heard that you cannot watch video back on the alexa. If this is true, how do you make sure the SxS cards are recorded to? Do you have to pull them out and then download them? How about if you use an external recorder, for RAW? Seems there should be a way to at least play back a small clip through on-board monitor before moving on to another setup?
Todd McMullen
Flip Flop Films
gary adcock
Re: check the gate
on Jan 11, 2011 at 1:15:51 pm
Correct Todd,
the current builds of the Alexa software do not allow for in-camera playback from SxS, that is scheduled for the next software release, as is ArriRaw recording capabilities.
External recorders are not limited to the cameras capabilities, so there would not be the same issues there.
gary adcock
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
© 2018 All Rights Reserved
