To RAID, or not to RAID...
COW Forums : RAID Set-Up
Charles Fasano
on Apr 22, 2011 at 9:09:38 pm
Aloha to All.
Allow me to begin by saying thank you in advance for any and all help. Please understand I am a marine biologist first and a videographer second so please excuse my elementary knowledge.
I am asking for assistance concerning RAID.
I have a new 2011 17" macbook pro, 8gigs RAM
At current, I have 3 firewire 800 2TB external hard drives. All 3 are brand new Iomega eGo's for mac (let's call them A, B, C).
They are connected to 3 different channels on the mac:
A to the expresscard34 fw800 port1
B to the same expresscard34 fw800 port2
C to the built-in fw800
Note: the expresscard34 dual port fw800 IS ALSO a dual channel
Also, I have a blu-ray burner in daisy chain with drive A.
I film a lot of HiDef footage for research and am wondering if it is advantageous or not for me to arrange these drives in a RAID configuration. These drives are solely intended for housing the video clips and render files. All project and working files are on my built-in HD.
If it is better to configure a RAID, Apple should help me walk through the process correct since I have Apple Care and the laptop is about a month old? If not, will I be able to get assistance here in this forum?
Again, thank you for any assistance in advance.
Aloha:
-Charlie-
Alex Geroulaitis
Re: To RAID, or not to RAID...
on Apr 22, 2011 at 9:30:04 pm
Generally OS X (along with Linux and Windows) wouldn't (and shouldn't) allow you to RAID separate portable drives into a single volume - for a good reason. Disconnect one drive and the whole volume may be toast.
I'd recommend getting a self-contained RAID with a FW800 interface like Stardom SohoRAIDs; G-RAIDs, G-Speed Q.
Alex (DV411)
Alex Geroulaitis
on Apr 22, 2011 at 9:37:27 pm
[Alex Geroulaitis] "I'd recommend getting a self-contained RAID with a FW800 interface like Stardom SohoRAIDs; G-RAIDs, G-Speed Q."
Some of these also come with an eSATA port; adding an ExpressCard/34 eSATA port to your MBP will increase the transfer speed.
Alex (DV411)
David Roth Weiss
on Apr 22, 2011 at 9:32:05 pm
Although I am normally a huge fan of RAIDs, and I suggest them almost all the time to editors who have been stuck with single drive configurations, I'm not a huge fan of striped drives daisy-chained together across FW-800 connections. Unlike eSATA drives, which seem to retain their RAID configurations when one of the drives is accidently knocked offline, FW-800 drives sometimes lose the configuration and refuse to mount, and when that happens you lose your media.
Others may disagree, but that's my advice based upon both personal and professional experience.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
A forum host of Creative COW's Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Charles Fasano
on Apr 23, 2011 at 1:57:13 am
Thanks again for the input gentleman.
I do have plans on buying the Thunderbolt RAID from LaCie when it's released this summer. When that happens, then these current ones become archives stashed in the safe.
Since I won't be switching this to RAID, is this the best configuration to have with this particular set of hardware?
Thanks again
-Charlie-
Fasano Underwater Productions
http://www.FasanoUnderwater.com
Fred Jodry
on Apr 23, 2011 at 2:33:17 am
It sounds like you are running through a reasonably large amount of material. While adding up the sum for your RAID drives needs also consider a tape backup unit. 15 years from now you could have an awful lot of data in your safe. I know I am not being too specific at the moment but I would recommend that you get a RAID about as good as David Weiss uses so your work drives do not make you spend your life in front of your editing computer. Aim for very fast RAID without huge storage on your hard drives. That is what the backup, restore is for. Your 3 firewire drives as sombre storage will not be much of a problem for now.
