Raid0 and Raid 1
COW Forums : RAID Set-Up
Milan Hazucha
Raid0 and Raid 1
on Nov 5, 2010 at 3:13:44 pm
I want to create HW Raid 0 with 2x30GB velociraptors for programs only and HW Raid 1 with 2x160 GB drives for data, video, etc. Is it possible to do? Is it a reasonable approach since I do not have 3 about equal drives for Raid 5 or four same size HD for 0+1.
Thanks.
Jon Schilling
Re: Raid 0 and Raid 1
on Nov 8, 2010 at 6:37:52 pm
Milan, I think the reason your post hasn't been responded to is that you didn't include what KIND of hardware RAID product (external)? internal? you're looking to use with the hdd's you have.
Jon Schilling | Vice President of Sales & Marketing
RAIDON-USA Technology
STARDOM Storage by RAIDON
15356 East Valley Blvd., Suite B
City of Industry, CA 91746
Tel: 626-333-7888
http://www.stardom-usa.com/
Milan Hazucha
on Nov 8, 2010 at 6:45:10 pm
Thanks Jon. I have Abit IC7-Max3 MOBO with socket 478, chipset 875P with on-board RAID. So it will be internal HW RAID.
Jon Schilling
on Nov 8, 2010 at 6:55:10 pm
Milan.
You may want to check the "abit" literature that comes with the card you want to use to see what they recommend, or contact them if not check their FAQ page. Unless someone on this or another forum is using & has experience with the same card - hardware configuration, your best bet is the manufacturer.
I will say this though, for the sake of simplicity, only run drives of the same make & model number, and capacity when dealing with any hardware RAID. I'd also highly recommend Enterprise class drives for the best fault protection & long term reliability, especially in a RAID setting.
Tel: 626-333-7888
Milan Hazucha
on Nov 8, 2010 at 7:04:57 pm
Thanks Jon, Milan
Todd Perchert
on Nov 8, 2010 at 8:32:05 pm
I'm pretty sure you won't be able to pull off the 2 RAIDs, but definitely check with the MOBO manufacturer. I'm betting it will be RAID-1 HW and RAID-0 SW, but again that is if your Hardware will do that.
TC
Milan Hazucha
on Nov 9, 2010 at 12:43:49 pm
Thanks TC, I will check with Abit. Milan
