LSI 9341-8i or SAS 9361-16I
COW Forums : RAID Set-Up
Margus Voll
on Dec 18, 2016 at 8:05:31 am
Hi.
I plan to build new workstations for my Resolve and VFX setup but have some confusion about drive array.
I have been looking on LSI products that i mention in subject.
What confuses me now is:
In specifications they both list huge number of devices that can be connected there.
My question is how does this affect performance?
Lets say i populate all 20 (26) drive slots on my chassis (internally as this is really big machine in one box)
I'm trying to figure out if i8 would cover my needs or should i think of i16?
Also i'm bit confused on SAS vs SATA drives. On specs they seem similar in speed specially the 6 and 10 tb models. What is your take on that ? SAS seems like fast connection type but it does not give additional speed if the spinning drive itself is limites to lets say 250 MB sec?
Margus
http://iconstudios.eu
Resolve 11
BMC 2,5k
Rainer Wirth
Re: LSI 9341-8i or SAS 9361-16I
on Dec 18, 2016 at 9:23:10 am
Hi Margus,
Question 1: Your max. performance is 12mb/s, bandwidth 8x PCIX. You'll get around real 600-800 Megabytes/s.
The difference between i8 and i16:
The i8 has 8 external mini SAS ports and supports just Raid level 5
The i16 has 16 external mini SAS ports and supports Rais level 5 and 6.
5 and 6 are the Raid levels, you are looking for.
To me the i16 is the better raid card.
But another question puzzels me: Do you want to connect 8 or 16 drives direct to the card, or do you have a cooled external box, where the raid drives do their job?
The SAS connection in the card is for data only and provides no power supply for your drives.
SAS or Sata is non-relevant for your data speed.
Look for support of your comuter system in the technical specs of the card you are going for.
Generally speaking: I would go for an external housed raid system, based on Fibre channel or thunderbolt instead of a software-based raid system, like the LSI.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Margus Voll
on Dec 18, 2016 at 9:46:27 am
Thanks.
Ok i have read now and yes it seems now that i8 is soft raid in a way.
As i do not have any ideas or comparison of other manufactures or models this is why i came up with these models.
Any better ideas i would appreciate.
I plan to build my own system from ground up in very large box so no external connection mandatory for now.
http://www.lian-li.com/en/dt_portfolio/pc-d8000/
This is the one i'm thinking of.
As i have pretty much one or two man band we do not need many big separate arrays.
My initial plan is to "see" mac pro 5.1 and win10 machine which i'm building over dual 10 gig network but if that will work is another subject on another thread.
Margus
Resolve 11
BMC 2,5k
Bob Zelin
on Dec 18, 2016 at 2:58:42 pm
and why don't you just buy a premade Chinese NAS that does exactly what you want without any aggravation ?
Bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com
Margus Voll
on Dec 18, 2016 at 5:00:25 pm
Because i'm not familiar any of those.
Educate me please.
Also lan part is secondary concern and working locally on one machine is primary.
Margus
Resolve 11
BMC 2,5k
Rainer Wirth
on Dec 19, 2016 at 11:07:40 am
Hi Margus,
let's begin from scratch. What is the main job your new raid array should do for you?
Second: What platform (Mac or Windows) do you want to play?
Third: How much storage do you need for your projects now and in the near future?
Do you work mainly in HD or 4K?
How do you want to do your monitoring? (picture, sound, colour)
You have to define and set up your workflow!
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Margus Voll
on Dec 19, 2016 at 11:36:46 am
Hi.
Sorry not describing my actual needs:
4k EXR for Resolve and Fusion as starting point
Win10 as i build new machine now on i7
Lets say i start with 40 TB. I have chosen big case so i can reconfigure my array how my need changes
Now HD and 2k but i have strong pressure for 4k
DeckLink 4K Extreme to my monitor so that is covered.
I have similar workflow now on mac pro 5.1 but it is already 6 year old and loosing some of it's edge as i can not do 4k
if needed and this is a bit limiting now.
It seems now reasonable to go over i7 for now and in couple of years if the need comes to jump over xeon.
Does it describe my workflow a bit in more detail?
Margus
Resolve 11
BMC 2,5k
Rainer Wirth
on Dec 19, 2016 at 1:04:30 pm
Hi Margus,
excellent, from here we can start to work.
For a proper 4k workflow you need roundabout 800 MB/s raid speed.
If you want to go for a SAS connection you are on the edge, but it is possible with Raid5.
The connection card I recommend is an ATTO ExpressSAS® H1248.
This provides you with 4 external miniSAS links and enough speed, plus software and support through Atto.
My recommendation would be a FC connection Atto Celerity FC-162E.
With a FC solution you can work on Raid level 6 for more redundancy.
The enclosure for your raid:
A SAS enclosure with 4 mini SAS external connections.
Or a FC Raid enclosure with 2 external FC ports (16gb each).
You should use just enterprise HD's 8-16 bay raid enclosures. Power supply and cooling over the external enclosure.
All HD's must meet the tech specs of Atto and the enclosure manufacturer. The HD's must be of the same kind (firmware number) and size.
There are numerous raid enclosures on the market, they must meet your specs and connect with the computer card.
I hope this helps,
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Rainer Wirth
on Dec 19, 2016 at 1:11:53 pm
a very good enclosure is Promise J5000,
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
alex gardiner
on Dec 20, 2016 at 4:09:33 pm
So what you're really describing is a shared storage server, not direct attached storage...
Unless you've done this before you're unlikely to get the kind of performance you need over the network.
To actually answer the question, the LSI 9361 is an excellent card, I work with them all the time. They perform very well, but MegaRAID Storage Manager is atrocious - hate it with a passion. Areca have better management software in my book, but the performance isn't really all that different between products at that level.
NB: As above, the 9341 is probably not for you.
Storage Engineer
alex@indiestor.com
Rainer Wirth
on Dec 21, 2016 at 1:52:59 pm
The problem is, that Margus want to built a SAS data connection.
SAS is much cheaper than FC or Thunderbolt.
With FC or thunderbolt you'll get faster performance, but you need a bigger budget,
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Margus Voll
on Dec 21, 2016 at 2:51:20 pm
Internally with SAS (or slitted to sata) is ok for now as i'm one man band for now sharing in massive amount is
not that important. I probably can get away with dual 10 gig net moving stuff around slowly.
I will leave DCP mastering and such on mac still but grading and vfx i will do on my win then with bigger array.
That is good point that 9361 seems better as it actually is raid.
I do not have as much knowledge for now how different models and manufactures compare to each other
this is why i started to ask.
As i still plan to get this huge box with 20 drive slots then internal is super fine for me.
(2x normal machine with enclosure)
Margus
Resolve 11
BMC 2,5k
