Single System DAS is 10GbE worth it?
COW Forums : RAID Set-Up
Jake Hawkes
on Sep 14, 2016 at 1:43:17 pm
10GbE to a single workstation is actually pretty hard to find any info on. I suppose that is because everyone uses TCP/IP for, well networking. Is 10GbE the best backbone for data transfer until you go up to a SAS connection on a PC?
I can't find is whether 10GbE is going to be 2X, 3X or 4X as fast as USB 3.0.
You've Had Our Potatoes!
Randall Packer
Re: Single System DAS is 10GbE worth it?
on Sep 14, 2016 at 2:29:14 pm
As far as I know, you connect the 10Gb port on a NAS directly to a computer that has a 10Gb Ethernet convertor, without using a switch.
Multimedia Artist and Composer
Neil Sadwelkar
on Sep 17, 2016 at 12:41:52 pm
10 GigE is theoretically 10 Gbps, so its theoretically 2 times faster than USB 3.0 which is 5 Gbps.
In practice, transfer speeds over 10GigE would depend on the drive/RAID speed, network overhead, and connection protocol.
Based on my observations on connecting a 10GigE host (Sony SRPC-4 with a Sony camera data pack) to a MBP with a 10GigE adapter and writing to an external Thunderbolt RAID capable of 800 MB/sec, I got speeds of up to 400 MB/sec. Others have reported speeds up to 500 MB/sec.
This is over SMB, so there's some network overhead too. Maybe some other protocol with less overhead may work faster.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
