Sonnet Fusion R800: what are the limitations regarding current HDDs?
COW Forums : RAID Set-Up
Philip Dygeus
on Oct 13, 2015 at 12:56:30 pm
Hello
Sonnet publishes a list of HDDs which are "certified compatible" with their various current and legacy RAID arrays.
http://www.sonnettech.com/Support/charts/harddrives/index.html
I'm wondering about the R800 which is an older model. According to Sonnet's list not many 2TB drives are compatible with the R800 and only one 3TB drive.
Would anyone know if the listed drives are requirements (meaning no other drives will work at all) or simply recommendations?
Thank you very much in advance
Philip
Rainer Wirth
Re: Sonnet Fusion R800: what are the limitations regarding current HDDs?
on Oct 26, 2015 at 6:28:15 pm
Hi Philip,
we are running a R800 for years now. It's still a good and reliable array. But it is no longer supported. So you should stick to the drive compatability list. Both 3TB and 2TB certified drives of the list are good choices. As a 4tb drive is not on the list, the hd will be most likely not supported.
Best drives for us are Ultrastars.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
