Pegasus 1st generation R4 replacement drives
COW Forums : RAID Set-Up
Doug Moore
on Sep 4, 2015 at 11:38:56 am
Has anyone used the Seagate Baracuda that are approved for the Pegasus 2 R4 on a first generation Pegasus R4?
Some support techs have suggested that the Seagate replacement drives that are compatible with the Pegasus 2 R4 have a high failure rate if used with the Pegasus R4 1st generation raid system, others say this is nonsense.
So I am just checking to see if anyone here has had success using drives approved for the Pegasus2 R4 in a Pegasus R4 1st generation system.
Thank you.
Rainer Wirth
Re: Pegasus 1st generation R4 replacement drives
on Oct 26, 2015 at 6:46:36 pm
Hi Doug,
I don't think its the drives. If they are certified for use with pegasus, then they should be fine. I think its the controller within the pegasus making the difference between first and second generation.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
